Picked up a 2017 Summit White Crew Cab LT with the 5.3 and E-assist. Nice having the extra ton of tow capacity and seeing around 22 MPG in mixed city/highway driving. I believe it is only available in California, Oregon and Washington.
It has some quirks with auto-shutoff at stop lights and the batteries on the floor under the rear seats.
Having difficulty to find any storage that will fit under the rear seats. Anybody find storage that works? At the lowest it is down to about 5".
Welcome to this forum! I am interested in hearing more about your experiences with your new truck. I came very close to buying a hybrid Sierra 1500 in 2009. I think this is a great power option for the type of driving I do but is no longer available where I live. I have a locking aluminum box in the back of my truck to keep all of the "stuff" I want in my truck for emergencies or occasional usage. I like to keep my back seat area clear of junk. There is plenty of storage up front for the items I need to keep close at hand!
Awesome! THis is something I tried to buy but was given the runaround and no deal to get it?
I fully expect GM to continue this and add dynamic fuel management with improved batteries and hardware etc. I am looking for the 5.3L to be bumped up on HP/Torque added 10spd and dynamic fuel management system and putting the MPG's numbers something like 20 city 26hwy.
I like this over ECOBOOSTS any day!
The hybrid trucks are mostly for city driving fyi.
There sole purpose is to basically regenerative braking, to capture all that energy we use slowing down.
If you're cruising down the highway, I doubt there would be much of a difference in fuel consumption.
Yes, they were originally pitched that way for city/haulers etc. Yet they net 2mpgs better on Hwy?
The system was intended for validation and technology before they up their game on next gen....I can guarantee you GM wants the coveted MPG crown for half-tons and using a V8 gasser over the ecoboost is icing on the cake! Never mind diesels not talking about those........
Agreed, I see the most benefit driving in the city but there is a little benefit on the highway., Only have 250 miles on it so far so we'll see how the MPG numbers hold up in the longer term.
The highway numbers come from eco tires and a nice big air dam. The hybrids from last gen were way too low to the ground.
I have a 2016 LT e-assist 5.3 wth 8 speed transmission. 13000 miles and no complaints except for the bolt falling out of the brake caliper bracket on the front right wheel, damaging the rim. All remedied under warranty.
I installed the GM version of the rear underseat storage compartment last night. Fit perfectly and operates as designed. Although a little pricey.
https://www.amazon.com/Accessories-23183674-Underseat-Storage-Compartment/dp/B0199WFB3A
I'm not sure if the "hybrid" battery placement changed for the 2017 models. If I remember correctly, mine is located under the center seating position of the front seat. If GM did relocate it under the rear seat, that would present a challenge with storage options.
  • 3 weeks later...
Reviving this topic. I've picked up a 2017 E-assist CCSB here in Texas. Texas Edition w/ 3.08 rear, 8-speed, 5.3L V8.
I was planning on transferring my AirRaid MIT tube, but come to find out the engine bays are different for the E-assists.
See pics below. Someone else chime in if you have some info. Looks like they relocated the radiator fluid to the front, revised the intake, and put the lithium battery beside the stock battery. The MIT tube hits the radiator fluid and doesn't have enough room to connect.
I'm told I can jump my stock battery with the lithium battery if my truck ever dies, pretty cool there. Hands down rides 10x smoother for some reason, the shifts are like butter compared to my old BBP tune.
Tires, wheels, tint, and clear bra for the hood/fenders come in on Thursday - exhaust will be installed back on next week. Fox 2.0s are back on with the BackFlip MX4. Kicker setup is back in as well.
Talk about a long weekend.
Edited by ChevyRoofer
Are you sure 8speed? I was under impression the 6speeds were for Eassist?
Yep, they definitely are the 8 speeds.
Thanks, I Like it much! I tried to get a 2016 to much of a hassle......What are your current MPG's
I hope they further the technology on the Next Gen
Averaging 21 around the city, haven't driven on the highway yet.
Picking up heavier tires tomorrow so that might change my MPG a little.
And I do too.
    B07
    B07
  • Who's Online   0 Members, 0 Anonymous, 737 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
