FXR Retrofit Help
Oldcabin01
Hi guys,
In the middle of an LED running light and FXR Retrofit upgrade. Just finished the biggest PIA opening up the headlights, but stumped on a small item.
How do I remove the "shroud" around the stock lens? There are 3 white screw like pieces holding it in, but not sure how to loosen or remove them.
Anyone done this before?
Pic below.
Thanks in advance!
Do note that this is for a kit from fastheadlights. So the. BRacket that they talk about is only if you bought that from them. Hope that link above helps in some sort of way.
