GM Quality Survey
For me, having worked at a dealership and knowing what these surveys are about, it ain't about them giving a shit about your issues just FYI.
That's exactly what I said. This is about them assessing the initial quality of the vehicle FROM the factory. I mean dude....do what you want, but they will take the feedback seriously. You just may not see it or hear about it. It may take a generation or 2 of trucks for them to make changes. And I'm not talking about programming changes for transmissions here. Fill it out, don't fill it out, I could give a toss.
Yet you seem so emotional about my decision. Warranty claims are used to track mechanical changes needed in the manufacturing process. This survey is just about ratings, that's it. Ever heard of JD Power, or any other that publishes ratings? Get out your feelings bro.
Your thoughts?
ROFL.....right there.....you asked our thoughts, I gave mine....yet you don't agree....but still asked, then you get emotional and defensive because it's clear to me, and others you didn't understand what they wanted..... As for JD Power.....VERY familiar with them. I will say for the last time....INITIAL QUALITY.....they want to see if the God damned factory got it right........you asked for thoughts....you got them....don't be so emotionally in trying to defend your thoughts of our thoughts. ;-)
:nonod: have a great day!!
I also disagree with your position on the 8sp transmissions. There have been a few people grousing about them, but they are a very, very tiny majority relative to the 500,000 + units in service. Are there some issues? For sure. But not near as extensive as some folks make them out to be.
Then why is it so hard for GM to fix the transmissions of the "very, very tiny majority"?
If it was really only a fraction of the sales with problems, why not just replace the trans with a new one?
The odds should be that the new trans will perform well.
so long
j-ten-ner
so long
j-ten-ner
I'm not in a position to make that call. Perhaps ask GM directly?
I think the dealer filled it out in my name, using a made up email address. They get $$$ for happy customers at time of sale.
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
