Hey everyone I'm new here and I am looking for a set of tires for my 2014 Silverado with the Rough Country 2.5 inch lit. I've seen many people run them with minor rubbing issues and if it rubs too much i may downgrade to a 295/70r18. I am keeping the stock 18 inch wheels as well. if youve done it let me know and if not, feel free to leave a pcik of your trucl with stock wheels, little lift and big tires! thanks and ill be looking forward to some responses!
  • 3 months later...
35/12.50 on  18x9 +18 Nitto ridge Grapplers .. 3inch level up front 2 inch out back.. zip tied in liners and not rubbing ... well until you flex it out which is rare..
I have 35x12.50s on stock 20s with a 6.5" lift and I come close to rubbing in the front in certain scenarios.  Hard to imagine you could run 35s with just a level kit.
RC 2.5 inch level up front with 295/70R18 Nitto Ridge Grapplers on stock 18s. It only ever rubbed on the liner, until I trimmed it a bit.
I am running 35x11.5 Nitto ridge grapplers on 2.5" RC leveling kit. I trimmed the wheel liner and it doesn't scrub anymore except on full lock it does hit the sway bar.
IMG 4157
Whats the point of running 35s if you cant even drive normally without rubbing, let alone anything offroad. Just run 33-34in lol
I do it for the looks. I love how dudes with 33s stare discreetly when I pull up next to them. Mine doesn’t rub on the streets and I have a set of 33s that I slap on once a month when we hit the trails. Works for me.
I DON'T like it when dudes stare at me....whether discreetly or indiscreetly.  :lol:
Neither do I lol but at my truck I don’t mind [emoji23]
These tires and wheels fit, and are for sale if interested (in N. Fl.)
Edited by krzyd
  • 2 years later...
I'm thinking of getting 35" or 34.5" tires, my truck is pretty much identical to yours. If I did a NorCal trim to the front fenders would that eliminate any rub when flexing? Also do you know what offset your wheels are, I currently have 0 offset 17" wheels.
    doylej24
    doylej24
  • Who's Online   4 Members, 0 Anonymous, 766 Guests (See full list)
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
    • Its just that it worked on 2024 trucks on this forum and my 2025 model truck, unless GM did something since that point to screw up access or Autel has a bad update. I haven't had need to use my tool since last year when I did the changes to the placard pressure settings and since then I updated the software on my Autel but have not plugged into the OBD so hard to say if I would get a surprise as well.    All I know last year when I bought the Autel I was warned to be sure to update it before I tried using the unit as they said who knows how long ago unit itself was actually manufactured as the software could be way out of date.
    • And so you had gone through the process of registering and updating the tool and so on ?. All I can say is that on the front page as the tool fires up you go to advanced mode, then vehicle model comes up and you choose Silverado ( not the DRW or EV  since your a single rear wheel ) , then I think its choice 2 which is 07/2021 - 12/2026 ( 433mhz 13542523 ) as that is the series of tpms sensors and then go down to choice 5 which is tire type/pressure selection. Hit yes and it says to connect to OBD port and turn ignition on.    Having said this, I updated the software in my tool lately and these year range choices look different from the past due to them doing some updates it would appear and I have not connected up to the OBD port since last year so hopefully I am not in for a surprise with them screwing up the software and that it won't work on my truck anymore either.    So my question is, when you plugged into the OBD and started your truck it had that message on the Autel screen "vehicle not supported" ?. That does seem odd as tire shops would be pissed right off if hey can't use their tool on the model year after mine that in theory is supposed to be much the same truck ... unless GM did some change in the computer system to block certain things from access.
    • Understanding and using modern scan tools is its own body of knowledge. I had little hope that would work...programming access to the BCM is probably required and that is not easy for us consumers. Expensive scan tool, GM programming subscription, online authentication, etc.   It also may be a matter of finding the right dealer to program it for you. Flashing a modern BCM might be a little too advanced for most tire shops.
