cam and other modification questions
I have a 2008 GMC Sierra 1500 with the 5.3. I'm looking to put a cam in it, but also thinking about putting a turbo kit on it next summer. My question is, what cam should I go with to get the most out of it now without the turbo, but won't be obsolete once I add the turbo? I don't want to go too crazy with it, since it's my daily.
My other question is, if and when I add the turbo kit, will my OEM fuel pump be sufficient in supplying or will I need to upgrade it? If so, what should I go with?
Before the cam I plan to do a new cold air intake system. Was also wondering if the stock injectors and throttle body will suffice after it's been tuned?
Thank you in advance for any input, I'm pretty new to all this, so anything helps.
