2014+ Silverado / Sierra silver dash trim pieces
RadoRage
Bought a 2017 sierra 1500 and it has a completely black dash and steering wheel (except for the chrome trim around the logo on the wheel). I am looking to break the black color up a bit and was thinking of buying a set of the trim pieces that are silver and go around the radio, left most vent, right most vent, and the 2 skinny pieces on the wheel (I'm assuming the dash is the same from 2014 thru 2017 as my 2014 silverado had the same dash but with the silver color trim).
Was curious if anyone has done this (assuming a direct fit across all trim levels but want to be sure). I was also thinking of wrapping the ones i already have in some vinyl as a cheaper option if I can get the same color/look so if anyone familiar with 3M color codes could point me in the right direction as well as if the vinyl will look as good as the ones from GM.
Anyone with experience doing either of these options?
Here are the options from GM and their cost:
GMC Axiom brushed aluminum trim:
Right trim 22825704 $105.87
Left trim 22825701 $139.42
Center trim w/o heated seats 22825711 $192.08
Chevrolet "High Country" silver painted:
Right trim 23136579 $49
Left Trim 23136576 $57.70
Center trim w/o heated seats 23136584 $83.10
There are other finishes available, such as burnish, synthesis, and combat.
Where are you located? I'll trade for black pieces...I hate the silver :driving:
I’m in TX but looks like you have an LTZ so you have the cutouts for the seat heat/cool. I do not.
Here are the options from GM and their cost:GMC Axiom brushed aluminum trim:Right trim 22825704 $105.87Left trim 22825701 $139.42Center trim w/o heated seats 22825711 $192.08Chevrolet "High Country" silver painted:Right trim 23136579 $49Left Trim 23136576 $57.70Center trim w/o heated seats 23136584 $83.10There are other finishes available, such as burnish, synthesis, and combat.
Wonder why the axiom trim is so much more. Is it real aluminum? If so I’ll probably go with the high country painted as its the silver I want and much cheaper.
That's interesting -- I thought heated seats were standard on High Country ...
    250.3k
    No1UKnow
    No1UKnow
  • Who's Online   6 Members, 0 Anonymous, 1,006 Guests (See full list)
    • Hello All!   My 2019 Colorado 3.6 LT, 4WD Crew Cab has approximately 77,500 miles and I recently began experiencing the well-known transmission shudder between about 30 and 65 mph. The problem had worsened to the point that I could no longer attribute it to road conditions - and I had decided to bring the truck to the dealer - when recently, I experienced a sudden loss of power while driving at maybe 40 MPH. Several warning lights flashed, the “Check Stabilitrack” message appeared, and the Check Engine, Stabilitrack, and Traction Control icons remained illuminated. The truck regained driving power, but it stayed in a low gear with unusually high RPMs for the speed. (limp mode?) Because I was only about two miles from home, driving slowly, I was able to make it back and run an OBD-II scan, which showed fault codes U0101, P0700, and U0100. My next trip in the truck was to drive it to the dealer the following day. That trip began normally, but after about a mile I experienced another loss of power, along with the same warning lights and the same “Check Stabilitrack” message. As before the truck remained driveable, but again operated at an abnormally high RPM-to-speed ratio and seemed stuck in a single gear. About a mile later, the dashboard lit up once more, this time displaying “Check 4WD.” Soon after that, I arrived at the dealer. I have verified that the truck still has its original factory transmission fluid, which means it has never received the corrective fluid exchange outlined in GM Technical Service Bulletin #18-NA-355.  That was Thursday of last week and I've heard nothing yet from the dealer.    According to Technical Service Bulletin #18-NA-355 and the build date of my truck, my truck should have the newer LV fluid. I've done a little research and read something about a problem with the wiring harness as well.   Anyone have an insights into this situation?  Thank you!!
    • Having bumper and other body damages can be very frustrating, especially as a result of a parking lot collision/bump. Our team wants to learn more about the damages to your truck so we can look into ways we might be able to help. When you get the chance, please fill out our support form with more details: https://s.gmc.com/support-request . A member of our team will follow up with you as soon as next available. We want to get you enjoying your truck to the fullest again.
    • Did you even read this article?   Even the title of the article says "U.S.-Iran Deal Doesn’t Mean a Swift Return of Oil and Gas Flows"   Remember, crude oil prices are based on FUTURE purchases by the oil companies.  Gas prices are based on FUTURE purchases by the station.  This article stated that many of the oil producing nations have to restart their processes to get the oil produced.  Then the oil has to be shipped to wherever.  And it doesn't get there overnight.  And most of that oil is not coming here. Check out this site:  https://afdc.energy.gov/data/10621   A graph will pop up to show where the US imports their oil from.  Notice that there isn't a lot of import from OPEC and Iraq.  Most of the US import comes from Canada. The US oil produces are selling their oil on the open market, which is why the US fuel costs went up.  So you're correct, the US oil companies are going to slow walk the price downward.
    • Having codes and an engine light with no hints on what might be causing it is nothing short of frustrating. How long have these concerns been present? We want to know more so we can look into ways we might be able to help you. When you get the chance, please fill out our support form with additional details on your experience so far. A member of our team will follow up with you as soon as next available: https://s.gmc.com/support-request
    • Knowing the life of your brakes is a highly important status to keep track of. If you suspect your brake sensors need attention, please fill out our support form with additional details on your experience. When did you last take it in for inspection? Our team will follow up with next steps as soon as next available. Please include your username and GM Trucks Forum in the form as well. Support Form: https://s.chevy.com/support-request
