Lift Pump vs CAT Filter Adapter
Just purchased a 2015 Silverado 6.6L with 38k miles. Looks like I'll need to change the fuel filter within the next 5k miles.
I know at the very least I should switch the filter to the CAT filter with the adapter, but I wanted to know if a lift pump makes more sense when it comes to fuel economy, performance, and engine maintenance.
Up front the cost difference between the two is about $500-$600. Will a lift pump pay for itself in the long run, or should I just stick with the CAT filter?
If lift pump is the way to go, which do you recommend, and which GPH? Also, would adding a lift pump require getting a tuner?
Thanks in advance.
No tuner needed.
The CP4.2 is hit or miss, seems you can run one tuned and drain the rails and have no problems or filter the hell out of the fuel and never fuel the engine hard and still loose the pump.
Reason?
IF there were an issue and the filter and adapter were traced back to the culprit for a failure, then your remaining factory powertrain warranty could be at risk. Now, this may have been a fluke, but we did have an older truck (2011 LML) that came in with fuel delivery and running issues, and our tech traced it back to the filter. Customer had the adapter and a Cat filter on it. We yanked it and put an OE filter on, and the guy has had no issues since.
http://www.dieselplace.com/forum/4605936-post7.html
What lift pump do you recommend?
On second thought, should I wait until I hit 100k miles, since the pump is covered under powertrain?
If you are not tuned and still have a warranty then yes you should use stock Ac/Delco filters and do good record keeping on mileage and filter receipts, it's 14k to replace the fuel system on the LML...
    • Thanks, all. It sounds like keeping the software "as is" is the best course of action.
    • https://en.wikipedia.org/wiki/Overengineering   Excerpt from the above link: (BTW the above is a 90 second read)   [Quote]   A story about very precise engineering is given in the 1858 story The Deacon's Masterpiece or, the Wonderful "One-hoss Shay": A Logical Story by Oliver Wendell Holmes Sr., which tells of a carriage (one-horse shay) Because it had been engineered so that no single piece failed first – no piece was over-engineered relative to the others, and they thus all collapsed at the same time. A similar quote by Ferdinand Porsche claimed "the perfect race car crosses the finish line in first place and immediately falls into pieces."[5]   [End Quote}   By Engineering's  own definition then; the AFM and Torque Converters, 4-5-6 clutch assembly of the 6L80E, and a dozen other common chronic parts and systems failures are "UNDER ENGINEERED". And by their own definition done so with INTENT. Ya can't have it both ways OEM's.
    • Everything you need to know..... https://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-–-mirrors-explained/
    • I was in Utah this week attempting a bow hunt in the Wasatch mountains with friends.  On the evening of the first hunt, making my way across a ridge to a friends camp, the upper control arm on the driver's side separated, the CV axle got trashed, and the wheel was dang near at a 45 degree angle to the ground.  I was able to get it towed off the mountain and into town about 3:00 am, and spent the remainder of the night in an O'Reilly's parking lot.  Luckily, there was a Chevrolet dealership not to far away so I was able to get to the dealership and pick up a new CV and UCA.  It would have been a few days before they could have gotten to the truck and I brought tools with me on hunt since it was a two day drive to get there, so I did the repairs myself in the O'Reilly's parking lot.      What's interesting is that the UCA ball joint didn't break, it just popped out of the bottom of the UCA.  There was VERY LITTLE evidence of grease on the ball joint or in the socket, and you could see where the ball joint had warbled out part of the socket over time.  I guess that's what happens over 186K miles of use :)   Big Kudos to O'Reilly's for letting me work on the truck in their parking lot.  However, they made a $150+ off of me from the purchase of various tools, so I guess it was in their best interest anyways :)   Getting towed off the mountain.   UCA Ball Joint Socket   Trashed CV   Suspension disconnected and UCA and CV Removed   New UCA and CV installed with the suspension buttoned up.
    • My family still laughs at me when they see me drive up in the minivan. Same with less than a V-8 truck. It helps that I have choices. I don’t think I could only have a minivan as the one and only vehicle as much as I like it. And I wouldn’t pass up a good buy on an older V-8 reg cab GM truck. Could you live Raven as the only ride?
