Planefixerguy Posted October 27, 2017 Posted October 27, 2017 Recently switched my gears from 3.08 to 3.73. Rear end went very well as I had a buddy of mine who is GM master mechanic. Bought a used front diff thinking it would be easier than rebuilding....I was very wrong. The one I got went to shit after 500 miles. So now I have rebuilt it but need help with the proper procedure for setting backlash and side bearing preload. I was planning on having my buddy help but he had something come up and is unavailable. I need to get it back in my truck this weekend. I have a 2010 Silverado 5.3L with 8.25 IFS.
Mike GMC Posted October 28, 2017 Posted October 28, 2017 Go buy a book. Trying to type out all the rebuild direction would nearly be a book. Besides, the pictures are usually a big help.
bgbdwlf2500 Posted October 30, 2017 Posted October 30, 2017 On 10/27/2017 at 5:58 PM, Planefixerguy said: Recently switched my gears from 3.08 to 3.73. Rear end went very well as I had a buddy of mine who is GM master mechanic. Bought a used front diff thinking it would be easier than rebuilding....I was very wrong. The one I got went to shit after 500 miles. So now I have rebuilt it but need help with the proper procedure for setting backlash and side bearing preload. I was planning on having my buddy help but he had something come up and is unavailable. I need to get it back in my truck this weekend. I have a 2010 Silverado 5.3L with 8.25 IFS. there is plenty of documentation and video online on how to do it, it doesn't look hard as long as you have a bearing press, just time consuming, which is why I haven't swapped my rear gears out. that being said, did you have any abs issues from changing the ring and pinion gears out? I'm wanting to do the same as you did but was worried it is going to throw off the abs and cause major issues. my truck is 2wd so I don't have to worry about the front
Planefixerguy Posted October 31, 2017 Author Posted October 31, 2017 16 hours ago, bgbdwlf2500 said: there is plenty of documentation and video online on how to do it, it doesn't look hard as long as you have a bearing press, just time consuming, which is why I haven't swapped my rear gears out. that being said, did you have any abs issues from changing the ring and pinion gears out? I'm wanting to do the same as you did but was worried it is going to throw off the abs and cause major issues. my truck is 2wd so I don't have to worry about the front No I did not have any issues with my ABS. It did throw off my spedo by about 10 MPH though. Still saving up for the programmer to fix that issue. I have been very happy with the swap so far. Going from a 3.08 to a 3.73 is a very noticeable change, especially when towing my camper.
silveradosid Posted October 31, 2017 Posted October 31, 2017 go here step by step with pics http://www.truckmodcentral.com/forums/f168/rebuilding-gm-8-25-ifs-differential-**56k-beware-pic-heavy**-13813/
bgbdwlf2500 Posted October 31, 2017 Posted October 31, 2017 8 hours ago, Planefixerguy said: No I did not have any issues with my ABS. It did throw off my spedo by about 10 MPH though. Still saving up for the programmer to fix that issue. I have been very happy with the swap so far. Going from a 3.08 to a 3.73 is a very noticeable change, especially when towing my camper. That's good to know as that was my biggest fear, that id have it done and have to pay to have the abs corrected. I have a tuner already so I would be ok on the speedo issue. I'm sure that it made a ton of difference pulling, as gutless as mine is unloaded I wouldn't consider pulling more than about 1000 lbs with it. My 07 that was lifted 12" had more guts on 35s with the 4.8L and 3.42 than this one has. running a 91 octane tune on e85 helps a ton but youre not supposed to pull with that tune .
