Air horn install???
2000silverz28
Anybody ever installed one of these? I'm helping my nephew install one and I have a few questions. The instructions it came with aren't much help. What I would like to do is hook it up to a push button switch instead of the horn button. It came with a relay but I'm not really sure what it does. It came with the air compressor which has a + and - hook up. If I get a push button switch it'll have a + and - hook up. My question is how do I wire this up using the relay or can I just forget the relay and just wire this straight to the battery? I don't want to mess anything up I just want to eliminate some of the wiring. Thanks.
Steve
Can't help w/ install but I have a few questions.
Where did he get the air horn...what brand, price?
I'm interested in getting one for my truck.
Thanks in advance, hope somebody here can help you out.
I put some small air horns on my motorcycle. The relay is there to keep the amps down that go through the switch. Most switches can't take that much power. Also, most switches use a ground to activate the relay. If I were you, I would run a power wire (either full time power or key switch power) to the relay, and then a wire from the relay to the switch. From the switch, just run a wire to ground. On the other side of the relay, you need to run a wire from the battery (or good power supply), then from the relay to the (+) side of the compressor. The (-) side of the compressor just needs to go to ground. If I had a diagram of the relay terminals I could tell you which one goes to what, but I don't have that in front of me. If there isn't a diagram, does it have numbers like 86, 87, etc.?? Just think of it as 2 separate circuits. The circuit with the picture of a coil on it is for the switch. As the coil is energized, it pulls the other switch closed, which provides power to the horn. The coil inside the relay is the load for that circuit (kind of like a light bulb). The compressor is the load for the other circuit.
I just helped a guy that does our alternators fix a kit for his four wheeler
I made my own We took the horns from one of our 18 wheelers and built a 2 gallon tank, and used a small compressor with a switch to turn it on so it wouldn't run off the battery all the time.
when you push 80+ psi through these bad boys you better have ear plugs
I installed my air horns last fall and i love them so much. I sound like a semi coming down the road. Easy to install, i made a mount for it.
when you talk air horns are you talking the 130db big rig bad boys, or the dixie plasitic airhors you buy at pepboys.....if your talking the big airhors...that's cool as sh*t, but where you gonna mount it, I don't need 12 inch horns on my roof or anything but it would be great to scare old people with...so where do you mount your horn...LOL
Can you give me the numbers off the back of the relay. Not the part number, the terminals on it should each be labled with a number. I can probably help you with those.
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
