Phil,
Yes my truck does have the button on the lower right corner of the HVAC control panel for the heated mirrors only. Lights up and heats the mirrors when I depress it and shuts off on it's own after some unknown period of time if I forget to !!
Edited by Enough
spelling error
Phil,
Very cool. I’ll look at the schematics again. I’m starting to think it’s the same circuit for both driven from the same button. Thanks!
  • 10 months later...
Hi, I have a 2015 Silverado 1500 LT, front and back defrost, powered mirrors and manual fold. I'm wanting to eventually get tow mirrors with lights, and might as well get it heated too. Would the heat option sync into the rear defrost as I'm seeing in the comments?
Looking at options on sites like rock auto or 1aauto that are compatible to my truck but don't specify the trim needed, should they work fine? I'd like the lights to work atleast
~Andrew
Hey Phil,
Are you still helping folks add heated mirrors to their LTs? Honestly I took them from granted in my previous truck and didn’t realize how important they were.
Jim
  • 8 months later...
On 11/5/2017 at 9:42 AM, pgamboa said:
This one is probably a little difficult.
The heat circuit at the door jamb that gets delivered to the mirror ties into the rear window defrost. So if you don’t have rear window defrost, you will not be able to gain this on the mirror.
I don’t know of a workaround to accomplish this.
Hello, I have a 2016 Silverado 1500 LT and have the heated rear defrost option. I recently installed a set of towing mirrors that have the heated mirror, turn signal indicators, and the LED puddle lights. The motor to move the mirror works great but would be real interested in getting the other features working. Is this possible?
Thank You!
Good afternoon, my wife just purchased me a 2014 GMC Sierra SLT 1500. I want to upgrade the mirrors to tow mirrors with cargo lights, turn signals and power fold if possible. Heated would be nice, but I don't know if I'll be able to get any of these functions to work because the stock mirrors are manual fold and power adjustment only... I see many options online to purchase the tow mirrors, but don't really know which ones to buy and I also see a stand alone harness that's supposed to make it plug and play, but I'm not sure it will work with my truck.
The build date is 10/13 if that helps...
Can anyone help me with the right mirrors at a reasonable price and also guide me in the right direction to make the mirrors work...?
Thanks in advance!
Welcome - Talk to Phil , at HarnessDR. com . he has help lot of people on this site.
  • 3 months later...
I have successfully added heated mirrors to my 2014 wt no rear defrost or heated mirror option. it was alot of work but can confirm rpo code of truck and it works. had to reprogram hvac module after all the wiring and swap out fuse box as well.  I took a picture of power to wire feed when hitting defrost button.  I just need a bcm reprogram for the windows and heated seats and fog light for next project.
    tararebecca
    tararebecca
  • Who's Online   3 Members, 0 Anonymous, 656 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need.webcrimsNY
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
