07 to a 14 bed swap
rickjames37
I'd highly doubt it. GM can barely keep stuff the same year to year, never mind 7 years after the new body rolled out.
The best way to find out is your local junkyard - they have the publication (name escapes me at the moment ... brain is rapidly aging ...) that tells them what fits what by make, model, and year, and can cross reference all of it.
