Trailer Battery (Pin7) not working
Rukus
2017 Silverado Crew LT Z71
When I bought the truck the fuse was blown (portion #2/30A fuse) for the trailer battery.   This also powered the interior lights in the trailer.   I replaced the fuse (trailer not connected) and the fuse blew instantly.  Tried another with same result (of course).  Took to dealer and they "no trouble found".   I pulled the fuse and they had a new one put in.  I took truck home and tested the fuse and it is good.   However, lights still do not work on the trailer.  (tried 2 trailers and get same results.) I have little trust for this dealer (for various reasons but it is where I bought the truck from 2 weeks ago.  I fear they just disconnected the trailer wiring for pin 7.  Any way I can check this?  Ultimate goal is to fix the issue.   Could care less about the dealer being shady.   Not a fan of the service Dept. at this point but just need the damn things work.  I know the trailers work as I tested them with my Jeep and they (1 of the trailers to be honest) worked 3 weeks ago with the 2015 I traded in.   Other trailer was about 2.5 -3 months ago.   Again, any ideas on how I can resolve this issue?   I am mechanically (and electronically) proficient.
Its time to get out the DVM / Digital Volt Meter or basic VOM to trouble shoot your power / ground issue..
Problem "could" be deffective relay,  wire crimp in harness or bad connector.
When fuse keeps blowing, grounded-power is usually the case..
Its unfortunate that some dealer techs have no clue on basic wiring..
Cheers----K
To solve your fuses blowing, you need to inspect that wire to see if there is any damaged insulation on it, or its pinched, or pulled out of the trailer harness. If it shorts out instantly, its touching bare metal somewhere.
Thanks for the info.... I fixed the issue myself... in the cold... on my 2 week old truck... that the dealer couldn't.  traced the lead back until I found a pinched group of wires.  (3 wires locked damaged/fixed all).   Good to go now.  If only the "mechanic" knew his ass for a hole in the ground.  The strike here cleaned out ll the good ones.   I, of course, will no longer go to that dealer.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 418 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
