Wiper blade arm adjustment
ram1067
Anyone know how to adjust wiper arm? I don't like how it leaves a streak down the edge of the windshield in my site line.
I think the are should go 1" further......  sorry for sideways pix....IMG_5242.JPG.4bf49d5797442048608127a5e43cba25.JPG
Clay the windshield. Then Aquapel. Maybe new wipers?
The issue is that the arm not the blade...I think the arm should go further to the edge of the wind shield!
Always seemd far enough over to me.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
