Whiney Allison
I have a 2001 2500HD 8.1 w the Allison tranny. It has 88K miles on it and is making a whiney noise from the transmission. How long does this transmission have or is it something that can be repaired w/o an overhaul?
It has a very small leak but drives and shifts great.
TIA for any advice.
My 2005 has been doing this since I bought it in 2004.  No problems as of yet.  Sometimes it's whinier than other times.
DEWFPO
TIA for any advice.
Change the spin on filter would be my first approach and if I remember correctly they also have a drain plug so I would drain what you can and refill
Well,got my tranny fluid analysis back and it's pretty crappy. Scores 3 on a scale of 0 to 4, with 4 being critical. I'm doing the double change plus filter. Using the crazy expensive Mobile Delvac 1 synthetic ATF.
Fixed the small leak... turned the filter half turn by hand, then tightened. No more drops.
I think the previous owner never changed the fluid. Truck runs and shifts great. Hope this transfusion gives some more miles before trouble.
BTW... got the pump rub cure at my local shop for $325 total. Installed case saver plus new fluid
Merry Christmas to all, Mike
change the internal filter this time and then just religiously change the spin. a few short interval drain and fills if it has the plug will help also, maybe just a quart or two at a time. I knew a guy that had about the same model truck as yours, didn't realize it could have been an Allison at the time but his whined all the time, even from new he said
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
