2 hours ago, Crobinson16 said:
That looks good, I'd love to see that setup with the chrome bumper still chrome with grille and headlights white. Did you have to take the headlight trim off to wrap? How is it holding up
Thanks Crobinson! The bumper was wrapped first so I didn't get any pictures of it with the bumper still chrome and grille/headlights white. Nothing had to be removed/disassembled from the truck during install. The vinyl is holding up really well for the most part. The only issue I have had is near the front bowtie emblem. The vinyl is starting to separate/bubble from the chrome in the corners (see picture below). I have to get pretty close to even see it so it's not a big deal for me. If it starts to get worse, I will just remove the vinyl from that middle grille piece and put some fresh vinyl on.Vinyl_Issue.thumb.JPG.459974695d373d442a67f73e0e71d347.JPG
I like the mirror wraps you have Looks Good , just watched some videos on wrapping on you tube, amazing what they can do, even to chrome wrap to help with rock chips on chromed fronts, if you can do it yourself it is cheap to buy!  , they even have a color match graphite metallic wrap that would match my paint  Nice post
Where do I find I reputable shop to do this, I believe though you said you did this your self. I'm in South Central PA
How far is that from Harrisburg PA?
Sent from my SAMSUNG-SM-N920A using Tapatalk
Here is some photoshop for you guys.....
I'm about an hour west of Harrisburg,
You should look up Inshane Designs in Harrisburg Pa. He does a ton of wrapping jobs.
Thanks, that's what I was hoping for, I do like that look, Im going to check out the vinyl option, definitely for the headlights as I may just buy the gm accessories grill. Thanks for the photos it helps a lot.
Is there a GM option that comes from the factory with a color matched grill and chrome bumper?
Not to my knowledge, z71 in any trim, get color matched and non z71 lt in any trim level get chrome grill and bumper. I haven't seen anything yet with split.
On 1/3/2018 at 11:28 AM, AlexMX88 said:
I had most of the chrome on my Summit White LTZ wrapped a couple years ago. Here are some photos:
Front bumper, headlight covers, and grill
Rear bumper
Front bowtie
Rear bowtie
Mirrors
I ordered a bunch of gloss white vinyl samples from MetroRestyling website. None of them were an exact color match but the Avery SW900 Supreme Wrapping Vinyl Film Gloss White was the closest. I ordered a 5ft x 12ft roll of it and ended up with a little left over. I also ordered a 1ft x 1ft piece of the white carbon fiber to wrap the chevy bowties.
Alex, your truck looks awesome with the wrap. I ordered my LTZ and at the time, I liked all the chrome, but 3 years later I wouldn't mind losing some of it. I'm going to have to look into this. I think my problem is going to be getting a color that matches well as mine is Siren Red.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
    • You refuse to own anything made in this century yet you reportedly own... a 2007 Silverado, which is now almost 20 years old. The dissonance.... turn up your hearing aid?   You clearly don't understand the government contracting process, brother. We send people to die on front lines, keep the public safe, and make people's husbands, wives, children enter burning buildings with equipment from .....wait for it.....   ...the lowest bidder....   Just because something is used for a long time doesn't mean it's good. But it might be cheap and plentiful.   Please, continue to whine about new trucks in a thread dedicated to new trucks, which you've said you'll never own. We get it. Go tell everyone how you're stuck in time on a Panther forum. I mean, Jesus, an 86 isn't even one of the good Panthers.
    • It really is comical when people don’t agree or see the reason some people prefer the older vehicles. They become condescending. All the while they may be busting their knuckles on old vehicles. I have found memories of swapping out engines in my old GM cars in a weekend without much hassle. Unlike today. One wrong move a computer will shut you down. Even on something as easy as a brake job. There’s a pretty comical YouTuber called the car wizard. A garage owner who puts it all in perspective. Another Vicegrip garage that’s shows just how tough the old stuff is.
