2017 5.3L/8 speed lugging at throttle tip in
SGS_Z71
Update:
GM now has two field service engineers at the dealer, working with a ASE master tech, trying to figure it out.  Wish they would just call it and take it back to the lab so it can be used to help others.  They’ve had it 20 days already, just this time.  Puts us well over 40 days in total. So done with this.
  • Replies 147
Update:
With the money they’ve spent on engineers, they may as well give you a new truck!
I don’t even want a new one from them, I just want my money back.  But yes, one would think it would have been easier to move me into another by now. I would have accepted it before, not anymore.
Update (Day 24 on 4th repair, 48 days total):
I was contacted today by the dealer that they have detected an issue and are pulling the cylinder heads off the motor today.  They could not elaborate more.  They are putting together a trade assistance offer for me, which I most likely will not accept.  I will share more when I know more, but it is nice to know that they owned up to there being an issue.
Stay tuned!
Stay tuned!
That is at least a step in the right direction.  I have contacted the Chevrolet assistance center again and am waiting for another call back. I told them this is absolutely unacceptable. A manager is supposed to be getting in contact with me. I'll keep you updated.
Update (day 25):
This is the latest from the service manager.  Unbelievable they are still working on this.  What in the world are they looking for?  Cracks??
GM engineering had us remove both cylinder heads to inspect the piston rings and cylinder walls which all checked out good, we have the cylinder heads off still and we have removed the lifters, valves and springs for inspection also. I have someone coming in today to look over everything. Our tech isn’t seeing any issues with anything but there is the possibility of something that we can’t visually see. I will update you after the rep from GM leaves today.”
Update (again):
They are replacing the lifters and valve springs.  This is some weird stuff.  Fuel injectors fixed in temporarily, now this?  I just can’t connect the dots on it.  Sounds to me as if they are throwing parts at it again.
18 minutes ago, SGS_Z71 said:
Update (again):
Sounds like it to me too.
I had a call from a district manager today as well. They are going to be talking with the dealer. Not sure where this will go.
Good luck!!!
Here is more information I just got:
“Well I got an update from my tech just now, he found an issue with the intake valve guide on cylinder #5. There is slight end play on that valve compared to the other valves so we are going to be replacing the cylinder head on the driver side. The tech has talked with the engineer and they both agree that this could cause incomplete combustion on that cylinder intermittently. So there is a very good chance we found our smoking gun. Now we have a lot more confidence in this repair. “
Update (day 28, 52 total):
I have been notified my truck is back together and “fixed”.  Meeting with the dealer today to pick it up and discuss replacement options.  I don’t expect them to have a solid proposal for me.  I have zero interest in staying in this vehicle.  If the root cause is valve guides and springs, I am probably done with GM altogether.  I wrote them off before on a Grand Am 3.1with bad valve guides at low mileage that they wouldn’t do anything on, but I came back several years later for another try.  This is GM #2 on the retry, first one was perfect (14’ Sierra).  We shall see, don’t know how the meeting is going to go.
Went to pick up the truck, took a drive with the tech and it is still doing it, although improved.  Some pretty concerning damage was found on the valve stem/guide on the #5 intake valve, but that still wasn’t it.  They did a bunch more, but I am officially done.  They will be putting a motor in it, but I am proceeding with a lemon law refund.
That sucks. Good luck to you.  I got the “normal” speech again from Chevrolet.  Called my salesman to discuss trade value but feel I'll be in the same situation as you.
Started lemon law proceedings with mine yesterday.  Have you heard back on your proceedings yet?
I am filing today. Calling GM this morning to notify them.
On 2/26/2018 at 10:04 PM, 13891 said:
That is good to hear.  Can you tell approximately what the ambient temperature is where you are now?  I ask because temps are over 40F here today and the symptoms are all but completely eliminated on my truck.  This is something I noticed early on in this mess.  The colder the ambient temperature is, the worse the symptoms were.  This is likely why I didn’t notice it when I initially purchased it.  It was the last week of August and of course temperatures were very warm.  We experienced warm temps right up through early/ mid November.  I suspect later this week when the cold returns so will the symptoms.  I would be curious to know if you experience similar results.  Keep us updated.
I just wanted to report back that mine does it all the way from 30 to 70 degrees.  I’ve driven in all of those conditions, still does it.  Wanted to close out this old post with a response that temperature doesn’t affect my issue.
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 463 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
