New to Forum, Not New to GM
CWOFOR
Hi folks, first time posting to this forum. Like the title says, not new to GM. I've been a GM guy most of my life. (Let my wife talk me into a Ford Escort back in '82. But only once.) I've owned everything from a Vega to a Corvette and 7 Camaros (most recently a '16 SS, which was my trade for my '17 Silverado). I opted for the basic WT 4X4, with just a few upgrades ( black 20s, sprayed in bed liner) I really like the simplicity of my truck from the rubber floor covering to the actual shifter on the floor (for the 4WD) to the lack of OnStar and the AM/FM radio. I will admit I do miss the convenience of satellite radio on the long trips, but not enough to want the OnStar that goes with it. All in all I am very pleased with my new truck.
Now, if I may, I would like to ask a technical question. My truck came with a set of all season tires , which are OK so far; however I am making plans to go with a more aggressive tire . All of the tires I'm looking at are 2.1" bigger in diameter than the stock tire. (Stock 275/55R20 verses new 275/65R20) This will through the speedometer off a few MPH. I checked with my service rep, and after his research, he informed me that there are no provisions on the service manual for recalibrating the speedometer. My question; is this true? Or is it that GM doesn't want us changing their product? Also, has the aftermarket got around this? If so, any recommendations.
Thanks in advance.
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
