Changing Rim size and Gear ratios
Hello All,
Not having much luck finding information. My father just picked up a 2017 5.3 6sp with 10K on it. It came stock with 17 inch rims. The previous owner swapped/upgraded to 20in chromes.
Will this have any influence on the 3.42 in the rear? Forgive if this is a stupid question. I've never changed wheel sizes and don't fully understand the rear ratio concept
Thanks in advance!
Happy Truckin'
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
