Headlights dimming while turning?
Omallyyy
It was about -8 Celsius. Everytime I turned my steering wheel the headlights would dim? Is this a common thing or is there something else at play here? Did it with high beams too.
2015 GMC Sierra all terrain
Sent from my SM-G930W8 using Tapatalk
Does it do it while driving or just when sitting still?
Sent from my SM-G935V using Tapatalk
Definitely when I'm sitting still. Unsure about driving I thought it did while driving too but I'm not 100% I'll check that again tomorrow.
It could just be that since the truck isn't moving turning the wheels takes a little more work because of weight and grip that it puts a little strain on the electric power steering so it pulls more power from whole system
Could it be your truck’s way of nudging you to move somewhere it wasn’t -8*C?   Like Miami maybe?
holy cow.
Sorry.   That wasn’t really helpful.   Hope someone here can give you a diagnosis.
I'm no tech but if you have electric power steering maybe it has something to do with it, i would call GM customer relations and let the company check that out.
Maybe there is a loose ground or short somewhere.
I would probably have the battery checked as a first step, most auto parts will test it for free. According to most reports the average battery life is 4 to 6 years so it would not be uncommon to see earlier than 4 year failures on a percentage of batteries. There have been reports (on this forum) about bad power distribution connections and cables but I would try to eliminate the easy and more common issues first. A nice AGM battery and you might be all set for 8 to 10 years?
