I have a 2007 Chevy Silverado 4 door 4.8l v8 I am having reduced engine power problems still after replacing several parts on the truck to fix the problem it remains and I need help please. I have replaced both knock sensors inside the engine block also the pedal response sensor as well as the throttle body sensor can anybody give me more info on this please.
IM NOT SURE ON BODY STYLE. IF I HAD TO GUESS ID SAY NEWER STYLE. I DONT KNOW WHAT CODES ITS THROWING. TAKING IT TO A SHOP IN A COUPLE OF WEEKS.
Here's a pic to help you determine which body style you have.  Codes would help others try to troubleshoot and give you an idea of where to start.
Check for bad wires on the throttle position sensor harness. There was an issue for a while where the wires would separate inside the insulation.
If you don't have or know how to use a digital multi-meter to check for continuity on the wiring, find a good mechanic that can help you out.
  • 5 years later...
I have a 2007 chevy silverado 4.8 1500 Classic. Pedal is sluggish. Looking at getting pedal commander, but will it work for old body style? Any one with the classic have the Pedal Commander?
