How does one get started creating custom diablo tunes?
What engine and transmission do you have? What Diablo tuner do you have?  I have an 18 with a 6.2 and an 8 speed, and I think the only option is to install the "diablo tune".  Then I can change for tire height and I think gear ratio and get rid of top speed governor.  I have an i3 8240.
And hello ex neighbor, I grew up in Defiance Ohio, went to Defiance High School.
you can modify timing, WOT fueling, tire size, afm/dod, gear ratio, tire size, speed limiter, rev limiter, etc with the programmer itself.. there's a listing on diablo's site of what some of the adjustable parameters are.
you can not create "custom tunes" externally to import into the tool..  that requires diablosport's CMR tuning software, which is only available to dealers/tune shops...
If you're looking for a custom tune, you check out www.diablewtune.com
You can also email me directly at:  diablo DOT help AT gmail DOT com  with your vehicle year, model, engine, tranny, any mods done to it, etc.. and I can provide you with more info about the programmers, the custom tuning, etc..
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
