Pull bcm pin
Cslack491
I am installing an OEM remote start and have to pull pin #24 on my black BCM but cannot figure out how todo it. I could not find any info on how to either. Any advise?
I believe there is a special $60 tool you need to use to depress the little clips on the pin.@pgamboa would be able to help with this I’m sure.
2015 Silverado LT Midnight Edition
4.5” CST suspension lift
Or actually thinking about it more.... there might be a little tab on the side of the plug that you press in with a flat head screwdriver
22 minutes ago, Cslack491 said:
Hmm interesting I’ll check it out.
thanks
The BCM doesn't need a special tool.  Just use a small flat head screwdriver to lift the TPA (Terminal Position Assurance) tab up.  The tab is usually white.  Once the tab is up, there is a tiny little lever on the inside of the slot of each terminal.  Looking at from the front, using a pick tool, gently life the lever up while gently pulling the terminal out.
Here is a video of my Illuminated Door Sill - How To.  At about 3:48, I show in some details.
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
