Exhaust pop at 60mph
Ed36rgz71
Have my truck with an electric cut out in between cat and silencer. when I got on the highway one night I floored it, no traffic so why not. From a stop floored it onto the on ramp (cutout open) and when I hit 60 mph I hear a pop from exhaust. I've done it 2 more times now to see if it was a fluke or not and pop right at 60 mph. It's 5.3 6spd, anyone else with an electric cut out or an exhaust set up that this happened to?
If your backing off at 60 an open exhaust will pop. If it’s still accelerating at 60 my guess would be your truck is adjusting to the sudden change.
If it’s right at a shift point, it’s likely torq management backing fuel and spark.
Sounds like a back off pop from an open exhaust
I keep accelerating. Thanks guys thought maybe something was wrong
  • 2 months later...
Sorry to revive this, however I had the same issue with my corsa exhaust. When I go WOT from a stop, it'd make a noticeable pop... almost like a back pressure pop. I talked to corsa, I talked with my intake to see if it had caused me to run too rich/ lean. No real answers from either, however S&B was a little more helpful with advice that corsa. Then, I finally contacted Black Bear about a tune and my issue. They stated that there's a fuel cut off at full throttle shifting from 1-2, and 2-3. After the tune was completed, no more popping.
    • I toggled my updates off a couple of years back. Since I don't have any CEL activity and the truck runs fine I'm happy to refrain from rolling the dice. I figure they've got it as good as it's gonna get. Recalls are another matter and I will strongly consider those if I get a notice in the mail.
    • We'll know soon. But at the end of the day they'll likely not take owner aggravation and costs into consideration. Probably the most important factor to them will be bottom line, along with units sold. Did they make money off sales of AFM/DFM-equipped vehicles? If yes, and the margin was large enough in spite of warranty and recall costs, I don't know that they will consider much else. Aside from government involvement of course, as in EPA and other regulatory bodies.
    • HM oils and cleaning. Well, soft deposits yes, perhaps. Like you say esters are present in in theory that should be a plus. But, is there enough? 🤔 The marker is the "Aniline Point" and it has to be pretty low to solve out baked on deposits. The softer sludge, yea, they do that and that is the claim. Valvoline R&P is the only HM oil I know of (Jury is out on Mobil 1's product) whose chemistry is uniquely able to remove the hard stuff and not be so aggressive as to swell seals to uselessness.    Oxidation levels in virgin oils blends is a good indicator of ester level and higher is generally a lower Aniline number and at one time we could predict without the $400 aniline test it's effectiveness. AN's, alkylated naphthalene doesn't show up in the oxidation test but does show in the aniline test and has become sort of a cheaper go to but most oils only add enough to solve the additive package. Not nearly enough to clean the harder carbon materials.   To your second question about does it matter. Yes is the short answer. Deposits are insulative. Those under the piston crown for example add octane requirement for knock free running. We don't' normally notice in todays motors due to Knock sensor driven ignition R-e-t-a-r-d. At least until the full slate of available values is consumed. Newer motors also often use oil jets to cool the piston to achieve tunes that would otherwise not be possible. Deposits on either side subtract from that. Deposits in fine screens used in VVT/VVL or DFM/AFM services live and die on cleanliness and screens are front and center. Vacuum pumps as well like brake booster in the K2's.    90% of todays oils are Group II+/III blends. A few more at PAO/AN/Group II's. A few boutique oils not Walmart shelf materials have enough solvency to prevent but not remove the hard stuff. R & P the current exception. Even HPL's EC30/40 used as directed (20% max) will get the soft stuff and some varnish out but not the hard stuff.    That orange varnish isn't baked on oil. Those are fuel varnishes left when the fuel diluted in the oil drops out when the oil cools. Like sugar does in a saturated mix of sugar and water that is put into the frig. That is ring sticking material and a glue the binds hard carbon sometimes.    Name brand shelf oils are intended to provide a useful service life at the least cost and highest benefit to the OEM who is trying very hard to keep you in $500 a month payment programs where the real money is made.   Did I miss anything you asked or left unsatisfied?
    • Yes, I understand. And I was saying (poorly), that it popped up on the DIC when I didn't have that info screen up. Just like you, but for a different maintenance issue. And just like yours mine didn't need to be shown at that time.
    • Ugh, amateurs.   But I did learn HM seal conditioners are esters.   I'm curious about deposit removal - some of the HM oils claim they really clean stuff up, the old and hard to reach stuff, and that's great? To Grumpy's point, a good oil should already be keeping the house pretty clean. I assume there are hard to reach places (underside of pistons?) and things that just accumulate baked-on oil and combustion vapors. If the deposits aren't friction or combustion surfaces and the deposit is just normal "seasoning", is it actually important to remove it?
