6.0 doing some crazy things
Hi everyone. I drive a 04 GMC Sierra 2500HD 2wd with the 6.0 has engine. I’m very machanicily inclined, but I’m scratching my head on this.
It runs great, idles a litttle rough but not bad. My scanner showed an engine misfire of 7 times on cylinder 7 with 3 minutes of run time at 2500 rpm.  Now to the problem. When I am driving down the road it runs great gets up to speed well. When cruising, I try to down shift to accelerate, engine revs to 3000 rpm, and falls on its face. Rpms start dropping, speed decreases. As soon as I let off the pedal, it shifts and gets back up to speed. I’m not sure if the misfire could be making the engine do this. I’ve had similar problems with another truck, ended up being the cat converters. I have deleted them on this truck to attempt to fix this issue. New TPS, new plugs and wires. Does throw a code for 02 sensor every so often. But only comes on once in a while.
 I’m scratching my head on this one. Any help would be greatly appriated.
What do you mean by "deleted them (cat converters)"?  You just removed them or did you also get the truck retuned afterwards, with a tune that is coded for the truck not having them.
There is a specific, fairly simple test for if the cats are causing a problem (you measure the pressure at the upstream O2 sensor), and if it's more than X psi, then the cats are plugged.
Anyway, it needs a tune specifically for having the cats deleted.
Once that's done, I would go for looking at live data on an odbii code scanner, to see what the ecm is doing when this problem happens.
I just removed them and did not have it tuned for that. I replaced coil pack for cylinder 7 and no more rough idle. The truck and the no return fuel system, no filter or pressure regulator, all in sending unit. Wounder if either could be going bad, going to check pressure tomorrow and will repost with results of test.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
