Thinking of buying
Wingnut
What do you guys think of this: Dune buggy.
I am not concerned about the blown engine. I would probably drop a motor out of a Corvair in it anyway. (More power, still air cooled, not to mention a Chevy product.)
The seller is a stupid sh!t, "Not being mechanically inclined I purchased this vehicle....".....What kind of retard that's not mechanically inclined buys a dune buggy?
I'm thinking that I can get a cheap toy out of his misfortune.
Let me know what you guys think.
Looks to be in pretty good shape. With a new engine and probably some rewiring it may be worth it. My brother started with a frame and ended up with this..........
All it takes is time and money. Being a good mechanic helps also.
Good Luck.
Sand rails are awesome!
Only things I hate racing in the dunes :thumbs:
Go for it! :thumbs:
Whooaa wait you had the OU sign up didn't you wingnut??? Do you go to little sahara? We are trying to plan another trip this spring. Either their or St. Anthony's... If I get the crew to go back down south, we should meet up !
I say buy it. There are so many good parts on there. And you could rebuild that motor for about $200 and sell it for $600. I would suggest just buying a 1800 or 2000cc VW motor for it. And get an external Oil Cooler. The VW motors and trans are bullet proof when properly taken car of. I used to have a 67 Beetle and what a fun car it was. I was able to blow Mustangs camaros and Vetts of the line. It was so quick. But after 2nd gear they were so far ahead of me it wasn't funny. You will have no regrets. And the moron selilng it didn't even put a reserve. So you might get it close to the price now. Wait to bid until the last minuet and put your highst offer. You will most likely get it. I am gutsy and wait until the last 30 seconds. Good luck and let us know how you make out.
Later,
Brandon
I would say buy it, especially if you know enough to fix it up nice. Good luck with the buy. You might even be able to get some money out of the existing engine.
No, thats the current owner that did that. After the previous owner sold him a buggy with "engine issues".
My money says that it's something along the lines of the previous owner probably had the oil drained for storage, and this guy didn't put any in before driving it because he doesn't know d!ck about "dem der mechanical thingies."
I'm not sure if I'm gonna buy it though. I'm just kicking around the idea, and thought I would axe yous guys.
I wouldn't be able to park the truck in the garage anymore. :thumbs: Not sure I like that.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
    • Same here, first I bought a few filters to get me going right after I bought my truck to do some short distance initial oil changes, then realized I could buy a case lot for less as they drop the price if filters or trans oil etc is bought by the un opened case lot as well as the discount for buying the vehicle there. So I have filters for a while but its good to know going forward, knowing to expect it to be a different part number and looking filter at the dealer and not be confused over it and think they are handing me the wrong part.
    • Saw Inglewood was in the National New last night for hail. Allot of hail. front end loader level hail. 😱
