Borla pro xs
I have been researching replacement muffler for 2016 Silverado 5.3 and finally pulled the trigger on a Borla Pro XS. Im going to have shop cut flapper valve off factory pipe and weld flapper valve in front of the the new muffler,Also going to leave resonator on. Im just looking for a little life out of system without the 4cylinder drone that so many have experienced.Muffler shop has been around for 40 years and has great reviews,only gonna charge me 50 bucks !!! Took off the hammerhead air unit and replaced with the AIR RAID JR,not only does it look better but feels a little more perky.
Forgive Me, What is MBRP and gibson ? Muffler or cold air
LOL ,.... sorry that made me laugh !  gibson and mbrp are 2 other cat back muffler and full exhaust manufacturers you tube have sound byte videos of different setups,  more affordable but not as high tech as borla !
weld the flapper is that normal ?  I don't think I heard of that .
or just cutting it out for better flow
Theres a guy on the forum who posted me a pic of his borla that has the flapper valve welded in front of the borla muffler. The gm factory version borla also has the flapper in front of the muffler not behind it like the stock muffler.Looks like they just cut out a section of pipe that contains the flapper ,butt joint it and weld it together.Muffler is being delivered on thursday,hopefully have it installed on friday.I 'll Try to post the results. The goal here is not to have to spend a G on a borla catback system. When its all said and done I should have less than 200 in the swap.
I believe they changed the design and location of the flapper valves in 2017.  It's in front of my stock muffler on my 5.3L GMC Sierrra Denali.
Thanks for the info on 2017. They musta had a good reason for moving it.Your system is stock GMC not a custom GM exhaust because of it being a denali?
I have the MBRP catback and it sounds great. I get compliments all the time on it. The drone isn't what people make it sound out to be. Barely notice it with the cruise on and the windows down. The 3" catback at idle sounds tough and when u accelerate... oh boy! And for $350 best money I've ever spent.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Is it the dual out the back? MBRP seems like it gets very good reviews and the price is great Thanks
  • 1 month later...
Any update on how this set up is working out? Any v4 drone? Looking to put the same set up on my 2015 Silverado 5.3
  • 1 year later...
2 hours ago, Graphite Silverado 2018 said:
Any drone in v4?
I took that option off, if i remember it did drone
Running same set-up. On my 17 there is no drone. Running single in/dual out with pipes out the back.
