Clunk noise when going over curbs/bumps
2017 Sierra 1500 SLT with Tow package. 25,000km. Truck has a clunk noise when hoping a curb or driving slow on bumpy roads.
Brough it for same issue about 8000km ago. They asked if I had the truck rust proofed. Which I had. They claimed they needed to lubricate an area. I didn’t ask where at the time and it did not state on the work order. Clunk was gone. Now it’s coming back.
Anyone know where it’s coming from? Definitely rear end area.
What is bothering me is lubricant is obviously only a bandaid.
I'm not sure what that clunk is. My 2006 Silverado did the same thing, my 2015 also make that clunk over certain things. I fig it must be the way they are. I drove my 06 for almost 10 years with it doing that and never had a problem. I guess I'm not to worried about it on my 15. I also would notice it over rough train tracks.
How would we know, could be anywhere... Why not just go back and either ask the dealer what they did last time or take it back in and have them note where it is since it still is underwarranty?
Am I the only one that laughed when mentioning going over curbs?
Tyler
Tyler
Nope, my first thought was "The solution is to quit hopping curbs".
My only issue was the driver seat.  Had shim GM shim kit installed.  Not sure if this is the same area or problem you are having.  It make a clunk over curbs and hard turns.
I had very same problem finally discovered shocks were bad in rear replaced and noise has been gone
    B07
    B07
  • Who's Online   2 Members, 0 Anonymous, 840 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
