Denali suspension help
First post on here so hopefully I'm in the right place.
I just picked up a 2015 sierra denali 1500 crew cab with the magnetic ride system and I have figured out I will need to shut down the ride system to be able to install 9 inch lift. Having trouble figuring out the best route to do this. Any help here would be really appreciated
On a side note GM dealer just replaced the front struts under warranty yesterday so I will have a new set of magnaride struts for sale shortly.
I lowered my truck and deleted magnetic ride. I used 3 ohm 100 watt resistors that I made a plug-n-play harness for shock connectors. Got to have level sensors connected to suspension or it will set a fault when you drive. I shortened the links in the rear to keep level sensors connected. Kept front connected in stock form. No service suspension message on when truck is started.
Here is the resistor and the harness I used to connect to shocks. I cut the female side off and soldered it to resistor. Taped everything up with fabric tape that is made for underneath hood or vehicle. Harness is from mercedes-benz recall for cam magnets. Connector is waterproof like factory shock connectors. I will get pictures on truck .
I just had a front shock fail on me and the dealer called and said that both rears were leaking also. They want a whopping 3200 for all 4. Needless to say I’m not getting them. Might try the resistor first before going to much farther.
Did you use the Benz harness for the connector to the factory plug? If so what kind of harness was it ie what year cam mag harness
thanks
Yes the harness has a male and female connector that plug directly into shock connector. I cut the harness and used the male side to plug into body harness. If you go to any mercedes dealer, tell them you need four harnesses for cam magnet campaign. I will get you part numbers later. One other place might be Casper electronics. I’m not sure how much the harnesses cost, I got mine from old engine. I work at mercedes. Resistors are cheap on eBay. I seen the kit mentioned, but was way more than the $15 I spent.
Does anyone know the part number for the connectors on the shocks.  I found the male end on the wiring harness and its GM 1-823608-5 but the shock female end does not have a part number on it.
Or, if you are not ever using your factory shocks, cut off connectors and strip back shielding to expose wires to install resistors.
So I've had the resistors installed for about a week now. But just had one go bad already.  It got really hot and melted the shrink wrap around the wires.  Have you had any issues with the ones that you installed?
Thanks
Colton
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
