Update:  After I installed the brackets the grille will not go back on. So I had to trim the brackets for it to fit. It’s a tight fit but it worked. See pic.6A998949-D52B-4EAE-A508-73B12704A7B4.thumb.jpeg.9855fe9235713708cefc43a1f50679e3.jpegThis is where I trimmed.  I actually trimmed just next to the bolt head through the washer. When I pull the grille back off tonight I will post a pic. of it cut
Got a link to these brackets? looking to do the same thing with mine
  • 3 months later...
On 8/23/2020 at 11:32 AM, flyingfool said:
anyone know what is required to install shutters on a truck without this feature???
It's probably tied through the computer which would require complete custom programming of your computer.
I don't believe there is any upgrade path through GM.
i will call HPtuners and ask them they should know
  • 3 months later...
So I added my light bar with active shutters today and it went pretty easily. I used the bar clamps and removed the bottom row of shutters so it won't block the light bar
  • 2 years later...
Also looking to know what size bolts replace the active shutter ones. I went to Lowe’s today and found that they’re m6x1.0. I couldn’t find a bolt long enough, how exactly do those spacers work. Please excuse my inexperience but I’ve never used spacers before. Thank you for any help you can provide
On 2/26/2019 at 12:04 PM, Evan Ingram said:
What size bolts went back into the bracket on the side of the shutters, through the 1/2 in spacers?
Also looking for this answer. Did you get an answer?
    250.6k
    liddlera
    liddlera
  • Who's Online   3 Members, 0 Anonymous, 734 Guests (See full list)
