Did you get everything installed?
Everything except for the rear shocks, going to do those tonight or tomorrow night. Front got installed Sunday. Angles look a bit suspect, hoping the coilovers settle a little in the next couple weeks of driving.
Looks great. You could throw a diff spacer kit on there if you’re worried about the cv angles. How does it ride?
The ride is great. I think the CVs look okay, the upper and lower arm balljoint angles are what concern me
Took some measurements, all are hub to fender:
Rear passenger - 22.75"
Rear driver - ~22.75"
Front passenger - right in between 23.5" & 23.75"
Front driver - 23.75"
So looks like ~3" of lift from these coilovers. Hoping they settle a little since there isn't much room for adjustment.
I’ve heard they settle about .250-.500 after a couple hundred miles. That’s what the guys at Procomp said.
Good to know. I'm going to try and get it in the dirt next weekend before taking it back for adjustment
Got a full size spare made up. Barely fits underneath.
Also went and tested out the coilovers/shocks today, they do pretty damn well.
You have lionhart tires all the way around?
Nope, just the spare. Found it "used" locally for $100. Never even been mounted.
    Chris80s
    Chris80s
  • Who's Online   5 Members, 1 Anonymous, 827 Guests (See full list)
    • Still $3.01 with even more places at this price
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
