BFgoodrich KO2
I’m doing a 2” leveling kit on my 2017 1500 LT and i’m just planning on using the stock 17” rims. I also want to go with some bigger tires probably 285/70/17 instead of the 255’s that are on it but i’m wondering if the  KO2s would rub or not. If someone else has done this it would be cool to see pictures as well.
I’m running 285/70/17 Cooper AT3s on Methods (0 offset) leveled with Pro Comp adj. struts. There’s all kinds of room lock 2 lock I don’t rub any where.
The other thing to remember is you’ll want to “recalibrate” your speedo with the tire change.
Look at 2009GMCs post in this thread he’s running hig GMC with 285 KOs on factories with the Bilsteins set at 1.5.
there’s all kinds of these threads on here as well as a wheel/tire thread that’s like 900 pages long so if your willing to put the time in searching I’ sure you’d find a exact match to yours somewhere.
This is what I did to find the wheel/tire/size combo I wanted to run.
I know i’ve tried but i think i maybe found one person that said 285’s would work and not even what tire it was i looked for awhile but just gave up and decided to post
