New 2018 Silverado 2500HD 4x4
Hey Guys,
I am a total Newb but am picking up my new Chevy 2500HD 4x4 tomorrow or Tuesday depending on upfitters progress.
I have been looking for a solution to list my truck about 3-4" (and level)
Problem is right now I need to keep my stock wheels and tires LT265/70R17
Anyone know of a good solution that won't destroy the ball joints or other suspension components?
I am looking at the Rough Country 3.5IN GM BOLT-ON SUSPENSION LIFT KIT (11-18 2500/3500HD)
and the Zone 2011-18 Chevy/GMC 2500HD/3500HD, 3" Adventure Series UCA Lift System, Zone Offroad C37N/C38N
I am hearing that the zone is the preferred brand of the two due to the fact that they are the sister company of BDS but I have also heard good things about the Rough Country.
Zone is $858 and RC is $599 that's $260 left to build more truck
Any help for this newb would be appreciated.
Thanks
Running Fast
Hey Guys,
Thanks
Running Fast
I think you get what you pay for. I have the RC 3.5” level and only went up about 2.5” (enough to clear my wheels and tires). The ride is stock... the UCA’s make the ball joints neutral. I’m sure zone has higher quality parts.. not sure. They have a great reputation.
just don't complain about crappy fuel economy!
Thanks WaaaZooo
Did you use the rear blocks and raise the rear as well or did you just level the truck?
Any Pics of your truck?
Thanks WaaaZooo
I didn’t use the blocks right off the bat. I wanted the UCA’s, shocks and Diff drop hardware. I knew I wasn’t going up to 3.5” just needed enough to make my tires fit with my aggressive fitting wheels.
I will put the blocks in soon. I have some sag with the trailer.f7a7b8aa6301df91e5dfbe01ef639548.jpg
Mr Waaazooo, air bags in the rear will eliminate  that sag, I've run them before with great results .Air up for towing, air down for daily driving.
Hey. I’ve used them before. I actually have a set of sumo springs I’m going to give a try to as well.
I lowered my back end as opposed to lifting and leveling.  I have Sumo's on the pickup.  Even with over a ton in the back, it sits level.   And i am old.  I need to get in and out of the back frequently and the lower height is a much better proposition for me.
Heard that, I am getting close to the same thing.
Gets harder and harder to get in the bed these days.
    contrabombarde
    contrabombarde
  • Who's Online   4 Members, 0 Anonymous, 1,395 Guests (See full list)
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
