"Wet" smell, possible leak?
Well, we've been getting absolutely hammered with rain the last couple months.  I've started to notice on and off randomly a wet smell in the truck after a heavy rain.  I had an old oldsmobile in high school that had a leak when it rained in the passenger floor board, and it reminds me of that same smell.  I've thoroughly checked the headliner, front and rear flooring, sunroof seals, window seals, etc.  Curious if anyone has had any leaks, and if there are any areas I should keep an eye on for them beyond the shark fin that seems to have an issue with leaks.  Can't seem to find a single damp spot in the truck.
My '17 had a leak and the dealer had no clue where for... (not sure why couldn't locate). It ended up shorting a lot of my electrical.  4x4 would engage when it wanted to.  Stab Track on/off... steering issues... etc...   They bought it back.    Last week (after 6 weeks of new truck) water was pouring in.   Was for the antenna AND the windshield seal.   Take your A pillar off and see if there is water in there.  Then take up your carpet and see if floor board is wet.   (carpet has rubber coating so it will not go through the carpet.   Been 2 days... I'll update again.
I wonder if my 17 has the same issue? My wife complained about a "mop water" smell the other day... I haven't noticed anything yet, but I'm in it a lot.
Sent from my SM-G955U using Tapatalk
My co worker had this issue with his 17, and my 17 just started to smell as well. After a quick call to the dealer, they stock the parts for the repair similar to how they do for a recall. They told me 2 hours for the fix, up to 6 hours if they find any other leaks....
Pull up the carpet on the pass side floor and see if it's wet under there.  I was getting water in mine and found out the wire harness grommet wasn't sealed all the way and it was letting water in and it would trickle down to the floorboard.  I found it when I was installing pgamboa's DL3 kit.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
