JohnnyH, you da man! I traded my 2008 Escalade, which had the magnetic ride shocks, air bags, and a compressor to keep the ride height and stability you wanted when towing. For a full-size SUV it was the best towing I had ever done. Now I have a 2016 Sierra Denali and my concern was not having air bags when I use my car trailer to tow the Jeep to the dunes or trails. I'm sure the truck would pull just fine without the air bags, but I like the better stability and ride quality - plus no crappy looking rear sag! Thanks for the air bag info, for $300 it's a no-brainer for me.
  • Replies 34
Top Posters In This Topic
3 hours ago, NWI Denali said:
Gorgeous Baja!
Thanks bud!  ? she’s a pain in my ass haha
Haha... nah, just trying to help people out. I had a 2017 GMC 1500 4x4 with 5,000lb bags before this truck. Got a deal I couldn’t pass up on the 18 denali. I thought that the magnetic ride shocks might be enough to keep it from sagging ( like you I hate how that looks and handles when u r driving)  I was pissed when I found out that bags might not be an option and just started googling everything I possibly could. Came across these and figured for under $300 wth, give it a shot... Got lucky haha. So now pass it on to everyone else that is in the same boat as me........
  • 5 weeks later...
Had the dealership do the Trim Height Relearn today and it made a big difference.   I had to track down the procedure as none of the local dealers knew about it but they did it for free for the help!
So to clarify and help others to install my Ride Control Bags:
1.) Remove the Load Levelers
2.) Modified the Wheel position sensor brakets
3.) Installed the Bags per the instructions running them on a common air line (Not Split)
4.) Made new Struts that connect to the wheel position sensor to the brackets using small threaded rod, shortened roughly 3" from the originals.
5.) Found that 20-30PSI was the sweet spot for ride height and comfort, empty cab & bed.
6.) Preformed a trim height relearn.
  • 2 years later...
    tararebecca
    tararebecca
  • Who's Online   3 Members, 0 Anonymous, 622 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need.webcrimsNY
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
