Bilstein 5100 shocks for 3"-3.5" rear block!
I'm currently running a 2.5" rear block in place of the factory 1.25" to keep some rake with my leveling kit.  I will be installing the Superlift 3.5" kit in the coming weeks, and want to install a 3" or 3.5" rear block to maintain some rake; also planning to install a set of 5100's at the same time.  I know bilstein offers the 5160 shock that will work with 0-2" rear lift, but I personally don't have the need for a remote reservoir.
So I went searching for a shock that had similar dimensions to the 5160, and I found the 2012 Dodge Ram shock, part# 24-187374.
Silverado 5100 #33-238319
Collapsed Length (IN) - 16.18
Extended Length (IN) - 25.79
Silverado 5160 #25-242515
Collapsed Length (IN) - 16.14
Extended Length (IN) - 26.81
Dodge 5100 #24-187374
Collapsed Length (IN): 16.75
Extended Length (IN): 26.73
I'm probably going to order a pair to try it out.
Another option is to use the regular 5100 that accommodates a 1" lift and add shock extensions. I have them because I swapped the 1.25" stock block for a 3".
The extensions I bought are very heavy duty, not a flimsy piece of junk.
I like doing it this way because I can use my stock shocks or my Bilsteins.. Or go back to stock height if I want and use any shock I want.
Right now I have Bilsteins in front and stock in rear. Seems to give the best ride on my 2015 NHT.
    • Check the windshield washer reservoir bolt. They ALL are loose from the factory.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
