Any DIY Home Experts here?
arkenzo
Bought a home recently, it was built in 1988 and has two central AC units ( it's a 2-story home ), does anyone know what these two things are? It's located in the garage and near the 1st furnace.
2nd is I'm going to install a ring doorbell, while checking my current doorbell transformer, I cannot get a voltage reading using my volt meter, what am I doing wrong here? Pic of transformer for doorbell is attached.
Any help is greatly appreciated.
Thnx
2f69380f299fe4310768b8074d5bb29c.jpg05c638be60b672781f9f9b5c3e99d85f.jpgf4f5cb8087df3e074afc09e025f91b58.jpg
The second transformer looks like it is for a furnace humidifier (24V). Is there one on the furnace or maybe an electronic air filter?
For the door bell, Both wires go into the bell box, but only one connects to the bell, the other wire goes to the door switch and then back to the front or rear terminal so that when the button is pushed the bell circuit is completed.
Either of these transformers can be used for the door bell most likely, they just need to be wired correctly.  Quick test is to attach one wire to transformer terminal from the transformer and briefly touch the other wire to the front or back terminals to see if the bell itself is working.
Not sure if I have a furnace humidifier, I'm guessing no. I do have two furnaces, one in garage and other on 2nd floor, could these transformers be for the thermostats? I have 2 nest as thermostats and they're working perfectly.
The doorbell works perfectly, I'm just trying to get a voltage reading with my multimeter so I can see if a ring doorbell or nest hello will work, I'd like to know if I have the right equipment before ordering. I can't get a damn reading from this doorbell transformer tho [emoji37]
Unhook the wires from one and try the bell and the nest to see which one it controls and then the other one do the same. No harm should be done to either by doing this as long as you do not short the contacts on the transformer.
The nest thermostat should be using the transformer built into the furnaces though. Maybe something else is using the second transformer like a garage door monitor or something similar?
If neither of these transformers are for the door bell or the nest thermostats and you cannot get a reading off of them, I would disconnect them totally until you found out what they are for.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
