GMC/Chevy Sierra/Silverado XD 18” 33x12.5r18 Toyo Open Country RT wheels rims tires w/ sensors & lug
This is a complete set of Toyo Open Country RT hybrid tires, size 33x12.5r18, mounted on 18x9” KMC XD series 127 Bully wheels with 6x139 bolt pattern and -12 offset. TPMS sensors are installed also. Complete setup has less than 5k on it and they look almost new. No damage or scratches, never off-road. Pictures are current. Comes with lugs, locks & key. Will mount up to any 6 lug Sierra, Silverado, Ir other gm vehicles.
I also have a 2” rough country level that can be included if the buyer wants it. Will work on all 07-18 gm 1500 trucks. The truck in the pictures has a 3.5” lift if anyone is wondering, but these wheels/tires will fit with just a 2” level also.
Pictures show how much they stick out, not much. No spacers have been used and there are hub centric rings included. Never any balance issues or vibrations on the highway. I am guilty of cruising at 80mph+?
Location- Central Massachusetts and willing to meet within a reasonable distance.
Contact- private message me for fastest response
Terms- face to face cash deal
Price $1400 cash
Thanks,
Mike
bd6fb2583ccb817add51ea423a0e1a17.jpg8aa00e9311711699ea47cd4af8803780.jpg1a94e5907007204fd757dc17869f5311.jpg4642afca515bd114e6fc44b9d783b079.jpgf08e9419d5f6162833905604c9332c60.jpg3dc1cad13e3c5f5f8f4b941c34219005.jpgcad95e371df45529af8c85d7a00a9888.jpgb17e0306ff9984328db773a61767fcc6.jpg571e17ce14c91cc4b7f66f1162b2a11c.jpg51a4f53734b1a33151e2c5876158b45e.jpg
Negative offset brings the tire in or pushes it out?
Sent from my Pixel 2 XL using Tapatalk
Pushes it out slightly. Stock offset is +27, the negative offset on these pushes it out about 1.5” as seen in the pictures.
Damn. I like the setup but planning to get a bds lift. So that would make things worse
Why would it make anything worse? Not familiar with the bds lifts.
The lift pushes the wheels already out an 1.5 inches so this would make it stick out even more.
If you’re using lifts that widen front track you don’t want negative offset wheels unless you like that weird look. I have 2 inches of widen track due to my RC lift and running my +18 wheels puts the tire 2 inches past fender which IMO is how it should look. I’m not a fan of half tire sticking out fender. If you’re doing a lift keep that mine. Depending on lift and size you may not get track width change.
What's that weird look you speak of? I spoke to bds and they are telling me for 18 inch to run zero offset. For 20 inch run +18 offset.
I spoke to customer offset and they told me either to run zero or a negative offset.
Hey guys, please don’t clutter my for sale thread up with all this other info. There are plenty of threads covering lift specs and wheel offset discussions. Thank you.
