HID low beam lights
hey just recently bought a set of hid lights for my 2015 Silverado 1500 Ltz. got them installed the power to the battery and grounded properly ballast hooked up correct and wiring harness. worked for about a day and boom no lights. swapped the harness for a buddies that he didn't use anymore and again after a minute this time and they shut off and wont work again. please help!
25 minutes ago, silveradosid said:
did you install capacitors
no I was unaware that you needed them actually. they help feed the power needed to the bulbs themselves? and where could I get my hands on them?
yes i learned the hard way to, you can buy the capacitors and wire them in or you can buy relay harness kits with the capacitors already in them go to ebay they are cheap
wicked tha is for the help. much appreciated!
there a link you could send for h11 relay harness with capacitors
