Scratches After GM Oil Changes
I bought my Truck new and it is 3 years old now. I religiously take my truck to GM for oil changes every 6 months. At 1st I started getting scratches on top of my plastic bumper pad. Like rocks in work boots. I then installed a Bull Bar and decided to polish it really good today. Now after having that installed for 1.5 years there are scratches all over my that from like work boots climbing it like F'cken ladder!
Has anyone noticed during basic service or oil changes if these techs climb the trucks like this. Is there a reason to get so deep under the hood. My truck has a level lift. I'm 6 foot and need a step stool to polish the very middle of my hood.
Go Check your trucks boys and check those top bumper pads for marks/scratches!
38085658_10214347110166265_8851277708374
37958611_10214347109086238_3024995318258
37963611_10214347109646252_6786220809271
37956025_10214347110846282_5786702131884
I had work done on mine (didn't fix issue, I can imagine everyone's shock) but the tech had to remove steering wheel. Instead of placing something over the door sill he just barrel rolled with his belt buckle scratching the painted surface. Seems to me the majority of these dealerships do not value their customers investments but only their initial purchase.
Sent from my SM-N950U using Tapatalk
No one will care about your vehicle as much as you do. The "dealership" doesn't work on your vehicle - some mechanic in their garage does. I never go to repair shops, because I am never happy with the results. I have won several free services for repair shop services - such as tune ups and oil change certificates. I frame them or put them in a scrap book, but I certainly don't redeem them. I do all my own repairs and maintenance, without exception.
Always work on your own vehicle if at all possible, especially something as easy as an oil change.  The problem is that a large portion of mechanics/garages these days do not take pride in their work and could care less about another persons property.  I also own a Jeep GC that had a recall where the headliner had to be removed.  Got the jeep back and the light gray interior was now covered in grease stains.  Had to force them to replace the whole liner.
I have learned to never Detail mine before taking to the dealer. Especially a black vehicle!
Hood and door fingerprints are everywhere when I pick my truck up after a service.
They do not even use the paper courtesy mats anymore but used to.
I will say the local Nissan dealer service dept. employees use cotton gloves and courtesy mats with my wife's car.
Yet another reason to install a forward facing dash cam...
Next time take a old bath towel, a Sharpie, and some duct tape with you to the dealer. Stop before pulling in and wrap bath towel around bull bar, secure with tape, write “4 your climbing on my sh!t comfort” or “scratch and dent sale thanks 2 u” or “place your dirty azz boots here” on the towel or a NO STEP sticker, ect. Switch it up every visit see how long it takes for somebody to say something to you, better yet get the camera then do this, we all want to see the look on the grease monkeys face as he reads the towel.
On 7/29/2018 at 7:18 PM, BC_Silverado said:
..My truck has a level lift. I'm 6 foot ...
I can feel your pain.
But, I'm 5'10" and my truck is stock height. I still have trouble to reach the dip stick or fill oil w/o leaning against the grill or fender.
A 2" level kit on my truck would give me a hard time to reach at all.
When they scratch your truck when it's stock, I'd agree with you. Because GM designed it this way and it's up to the dealership to deal with it.
But a leveled or lifted truck with a bull bar mounted...how is the mechanic supposed to work on it? Off of a ladder and leaning over the bar?
I think that WorkSafeBC (or similar) has a say in that matter, too.
so long
j-ten-ner
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 801 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
