2015 Silverado brake issues
CB15LTZ
Recently drove 2015 Silverado LTZ on long trip for vacation. Truck has right at 48,000 miles on it. Brakes started acting up as soon as I arrived.
I noticed the brake pedal acting up at a few red lights and then when we got to hotel the pedal went all the way to the floor before it came to a stop. Had it looked at by a mechanic. His computer showed a bad brake booster, so had that replaced and a new brake booster line, as well.  Everything else looked fine. That made the issue better, but still having problems when in reverse and if the brakes are pumped a couple of times before coming to a complete stop. On the way home I finally got a service brake assist message.
Just wondering if if anyone else has experienced similar issues and what ended up being the problem?
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 759 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
