Passive entry and push to start
Gm puts this package in many of it's vehicles, so I have to wonder... What would be needed, aside from the actual door handles and the new ignition to add the feature to my 2017 LTZ. Or is it even possible?
And as always... Enjoy your ride!
Sent from my SM-G955U using Tapatalk
Have any pics?
Potentially think you might need some BCM modification.
I actually spoke to WAMS about this and unfortunately, there is a lot “behind the scenes” stuff that make this all work. There are wireless transmitters that work with the Key Fob to determine proximity. These transmitters/receivers are wired to various locations, all door handles, ignition, etc.
Multiple modules, programming (if even possible). We didn’t go into any more details.
Yeah. So what you meant to say was, "it's not worth it" lol
This is also becoming a theft problem.
Sent from my XT1585 using Tapatalk
How's it becoming a theft problem? It actually comes with the auto door locks feature that prevents would be dirt bags from going through your glove box.
Definitely interesting, but afterall it is a mercedes.
Maybe the Silverado and Sierra are not as highly sought after :D
Without getting boring technical on the tech, it's actually fairly easy.
People won't be going through all that hassle for a regular pickup, that's 'Gone in 60 seconds' type of theft. Plus, you regular key fob signal and garage door opener can be copied the same way.
And just food for thought, no one has paid for that tech to jack my wife's minivan! And it's a swagger waggon! Lol
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 255 Guests (See full list)
