Rough idle- Vibration
At one point, I found an extensive thread, discussing the rough idle, and motor mount replacement situation. I'm unable to find it now. I'm been to two different dealers,  PICO scope at both of them, and they claim its within acceptable range. Talked with GM care, they want a third opinion. If the third is within range, It sounds like I'm either going to have to make the decision to live with it, or trade the truck in, and move on, or purchase the motor mounts and install them myself. Are the motor mounts a definite fix for this issue?
No i had the motor mounts done in 2017 mine still vibrates . The only thing that stopped it for a few months for me was to run sea foam through the top end  to clean the valves .
With my 2016-RCSB / 5.3, I have rough idle at times (only with engine is cold) and when at operating temp,, zero idle issues @ 14K on odometer
Discussed with Dealership service manager, by buddy and they did PICO test with no findings...
He has seen a few 5.3's with this issue, 2015 and newer but no real definitive cause..
As I only use Top Tier gas,, mostly BP, not worried about crap gas or water in fuel.
I have seen that some folks replace plugs and wires and have success in eliminating idle problem but this could be placebo affect..
Cheers---K
I had the mounts done. It changed the idle in that it's less noticeable while in gear and more noticeable in neutral.
It'll shake your phone if you have your elbow on the console out of gear. Otherwise its fairly livable in gear.
Cheers---K
Mine is more noticeable at operating temp, than anything. Top Tier gas here as well. Shell. I've seen similar posts as you , about plugs and wires and wondered if it really smoothed it out, or if it was placebo.
My 2012 5.3l got a rough idle on a cold start.
A few treatments of  Sea Foam helped.
I cleaned the MAF sensor with denatured alcohol and Q- tips and that helped.
Runs good now.
    B07
    B07
  • Who's Online   2 Members, 0 Anonymous, 692 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
