OBD-II port speaker popping issue
When I plug in my OBD-II scanner on my 97 Silverado, the radio cuts off and the speakers pop very loudly.
Is this a ground issue or a common problem?  My 96 Sierra never did this.
Shouldn’t every accessory, and anything else that draws power, be turned off when you use a scan tool?
That’s how I’ve been taught at any rate...
Ive had mine on the scan tool and it doesn't do that with the radio on.  Sounds like you have a bad ground or wire somewhere.
The question is where...
I've never had a problem with other vehicles.
Do you know where to find the ground wire locations?
If this has been moded with aftermarket radio or even alarm system, I'd look into the wiring of those as well. Someone may have tapped an incorrect wire
Completely stock
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 480 Guests (See full list)
