Car Play Update for iPhones
Mine looks completely different.  How do I find out the version?
And I did not see a shop app there.
Check sticker or build sheet
IOB - MYLINK(TM), 7" COLOUR TOUCH
Also, I don't think the store is available in Canada yet....
I also think it's offered through On-Star as a "sweetener" to lure people into paying for the astronomically high 4G data plans they offer.
20 hours ago, Loco-diablo said:
Just an FYI, but The newer GM mylink systems allow you to download weather channel app directly to the system. Not sure what system you have.
Have 2017 GMC yes weather chanel to the my link but not on Apple CarPlay
You don't have to get the On-Star (AT&T) data plan to use the MyLink apps like Weather Channel, Pandora, etc. You can tether the system to your phone's hotspot and use your phones data.
I do however have the unlimited data plan in the truck. $20/month is reasonable IMO
Right.. No weather apps project via CarPlay that I'm aware of.
The Weather Channel app via MyLink is pretty decent. I use it quite often.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
