2019 - Fog Lights With High Beam Hack
Anyone figured out the jumper hack to get the fog lights to work with high beams?  I know it's pretty easy to do this for the K2 trucks, but wondering if it's the same for the 2019.
  • 3 months later...
Anyone done this yet?  I noticed the brown connector that has all the wires seems a lot smaller than the previous generation trucks. Seems like a PITA to get a diode in there..
just realized this is under the wrong forum sections. Can one of the mod please move to 2019 section.
My husband just upgraded the old headlights with new HID kit to increase the beam a few months ago. But, due to fog, it is again looking dim and this time we are planning to exchange them with LED lights due to good beam and brightness.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
