I have a 2019 High Country that did come with all the cameras but the front one. I am having my local dealer install it. They said it was a plug and play. Just needed to have the infotainment system programmed. It is VERY pricy but I wanted it. Just FYI. It can be done.
  • 3 weeks later...
On 2/5/2020 at 6:48 PM, Josh99722 said:
Sorry i know its not the t1 style, I would still speak with mvi. Im sure they are working on it. Mvi keeps every retrofit oem.
search ebay for the kits. Bill craigem is a good one, email see what they have.
i would imagine ecomaster would make kits that are plug and play For the newer style.
go to a gm parts website and look through it, probably list the module harness camera in diagrams. Then find part #’s and start ordering parts.
https://www.group1autoparts.com/auto-parts/2019/chevrolet/silverado-1500/ltz-trim/5-3l-v8-gas-engine/body-cat/grille-and-components-scat/?part_number=84400532
Have anyone bought parts from this page ? Are they good?
  • 1 month later...
Pricey, as in $500, 1000, 1500+? I called my service dept and they said no can do....
1400.00 I still have not had it installed as the virus has me delayed. I also don’t have 100% confidence that this dealer knows what they are doing. I will update as soon as I find out.
  • 6 months later...
On 10/15/2019 at 8:57 AM, johnnypayne66 said:
Thanks for the links, but contacted them and they said they do not have a current option if your radio RPO code is IOS like on the 2020-2021 LT with 7” screen! It is silly that GM didn’t have an option of multi cameras on their Off-Road TrailBoss!  It would also be great for parking.
Edited by FuzzyNuggets
RPO
16 hours ago, ChriZ71 said:
Cheap and easy....
https://typesauto.com/collections/backup-cameras/products/type-s-wireless-6-8-inches-hd-solar-powered-backup-camera-with-extended-battery-bt530033
Available at Costco for a bit over $100 when on sale.
I put it on front LP because was frustrated could not gauge when close to poles, etc.
thanks for the option, but I am looking for something more factory that I can use my built in screen like the reverse camera. Thanks again
On 9/16/2020 at 9:30 AM, BossTaco2020 said:
Wow that sounds great getting up to speed and then, wooohooo breakin the law! ? Nice vid and I do like that sound. No drone at cruising.
SJF.... When you get yours installed can you please share info and pics.  I will go to my dealer and have installed.
35 minutes ago, FuzzyNuggets said:
Still no front camera that can integrate with the IOS radio (My OEM RPO code).... still looking
i have as IOS radio added 360 vision using info in link I sent.
On 10/11/2018 at 9:01 AM, Trailboss19 said:
Hi guys has anyone dug into the radio to see if it is possible to add a front camera to the system?
Thanks for any help
Here is one alternative that has worked out well on my 2020 Silverado Custom.
  • 1 month later...
Hi, I have a practically new MVI Front Camera Module for the 2019 through 2021 Chevy Silverado or GMC sierra. This is a plug and play module which integrates with the existing radio and activates the front camera after a reverse activation such as in a parking situation or can be manually activated at any time by double pressing the mute button on the steering wheel.
I recently traded in my truck and removed the Module after only a month of having it on. I paid $375 for it, but would be willing to part with it for $275 to recover some of the cost because I can’t use it on my new truck.
I can be contacted at [email protected]
Thanks in advance!!
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 266 Guests (See full list)
