Loss of power at WOT
I have a 1996 GMC K1500 Sierra Extended cab with the 5.7 engine. The engine starts and idles fine. It basically runs fine, except when I apply full throttle. It seems to be alot of noise, but no go. I will get error codes that indicate low voltage in the upstream O2 sensors, which means a lean condition (I believe they were P0131 and P0151). I've replaced the upstream O2 sensors, the Throttle Position sensor and the fuel filter and am getting the same results. The engine seems weak even when I rev the engine up while in park. I'm thinking it is fuel pressure related because the engine runs great except for WOT. Any ideas or thoughts are welcomed. Thanks
also check the usuals
air filter plugs and wires
and track down your battery and engine grounds
it does sound like you may have a problem with your
throttle body or your fuel pump
do oyu know anyone to chek the fuel pressure for you
Todd
DES......Sounds like your Cat. converter is plugged !
Take it to any major muffler chain....They will test
for FREE. Try that before you throw parts at it !
........geo
I don't have anybody that can check the fuel pressure, other than possibly doing it myself. I don't think this model has the "schrader" type valve since there isn't a fuel rail. The wires, distrib cap, plugs, etc. are fairly new. Hadn't thought about the cat converter being plugged. Thanks
  • 4 weeks later...
Well, I broke down and took it to the dealership. The culprit was the fuel pump. $500 plus to fix. I went ahead and let them do it. I'm tired of messing with it. I had replaced all of the usual and had narrowed it down to the fuel pump. They just confirmed it. Thanks for all the input.
I had that same problem on my 3/4 version of the 350 .
I just replaced the fuel filter and problem went away (even though i just replaced it back in march :chevy::flag: )
gonna have to have someone clean out these large fuel tanks here on the farm :(
Couldn't get to reply in time but, my friend’s truck did the exact same thing and it was the fuel pump. It took us a while to figure that out since the truck would idle fine and rev fine just wouldn’t do either in gear.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
