What is unique about the Max Trailering package on the 6.2L?
On 11/5/2018 at 8:06 PM, Nitrousbird said:
I have the 6.2L , Premium Plus, Z71 and I'm wondering what it would take to come close to duplicating the Max Trailering Package.
The only thing that can't be changed, thus the most valuable thing to some people, is the higher number on the payload sticker.  There's no changing that.  But if you aren't paranoid about the weight police, you can easily make the non-NHT tow as well or better in every way than a factory NHT.  That's what I've done with mine.
Tow Mirrors:  You can add them, highly recommended.  One of my favorite mods.
Rear springs:  You swap them or use airbags which are much better anyway.  Highly recommended (airbags).
Shocks:  The NHT gets slightly differently valve shocks, but they're still crappy.  Good aftermarket shocks will be better, highly recommended.
Gears:  Nice, but expensive and with a 6.2 and 8-Speed you may feel no need to swap.  They make a bigger difference with the 6-speed and/or if you go to bigger tires.
Cooling:  You can swap, of course, but the NHT radiator is only a tiny bit thicker.  I've done a whole lot of testing and shown the non-NHT radiator isn't the limiting factor in any commonly encountered situation.  You can have cooler temps than an NHT with a thermostat swap, and tuning the fans will help even more.
Trans cooling:  As mentioned, it's exactly the same.
  • Replies 62
The Max Trailering package can't be found on lots.  I have the 6.2L , Premium Plus, Z71 and I'm wondering what it would take to come close to duplicating the Max Trailering Package.
So here is what GMC's sight says:
3.42 rear axle ratio
- Yes, this one is a given - and an important upgrade.  Gear swap required.
Integrated trailer brake controller
- Available as a stand alone or part of a couple different packages - nothing unique to the Max Trailering Package
8-speed automatic transmission
- Premium Plus and Denali both have this
Increased towing and GCWR rating
- Just a rating
Automatic locking rear differential
- Isn't this just a standard feature on all the 4WD trucks?
Handling/Trailering Suspension Package
- Isn't this just marketing for the shocks and springs mentioned below?
Enhanced cooling radiator
- From what I've read, the radiator comes with a transmission cooler integrated into it without this package, and not just the regular flow-through cooler that has been done for decades.  What is different about this "enhanced" cooling radiator?  Different P/N?
Revised shock tuning
-  What is different about these shocks vs. base and Z71?  Would it be an upgrade or downgrade towing wise swapping to these shocks over the Z71 shocks?
Heavier duty rear springs and increased RGAWR
- What springs are used?  P/N?  How different are they vs stock/Z71?
9.76" rear axle
- Standard in the 6.2L trucks,
Trailer brake controller
- Yeah, it is listed twice
Trailering Equipment
- Uhhh, don't all the trucks have this?
From what I can tell and guess, there is a lot of marketing and the real differences are:
- 3.42 gears|
- Different shocks, but unsure what makes them different
- Assuming stiffer rear leafs - an easy and I'm guessing cheap swap
- "Maybe" a different radiator or external tranny cooler
Anyone with any insight on this?
I haves 2015 I’ll sell you.
  • 7 months later...
I found one in a dealer lot 20 miles from my house. Was even the pearl white color w/o a sunroof that I wanted. Perhaps would prefer a longer bed sometimes. But, short one fits in most standard sized garage's, barely and it's lifted 2". Drove it home 11/15/18.
Side note: had drivers side head replaced at 4,000 due to porous casting or something that made a pin hole in it.
Thanks to GM for the loaners I had for over a month while they got it sorted from a backordered head gasket, least that was their excuse for that long in shop.
Mean time I put 4,000 miles on the loaners taking my extended vacation time seeing the sights. Good timing I guess as I didn't rack up miles on mine. ?
    AidenVorpagel
    AidenVorpagel
  • Who's Online   4 Members, 0 Anonymous, 614 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
