Wife’s Denali came with 20s and my Denali came with 22s. Can we swap rims and tires and the sensors will still work ? 2016 Sierra and 2016 Yukon.
Thsnks guys
with my recent TPMS escapades I have concluded that there are two different sensors. There is a number 3 sensor that works for standard 1500 series trucks and there is a number 4 sensor that does not work for the standard 1500 series but HDs. The number 4 sensor is a higher pressure sensor with different frequency. The vendor that shipped out my sensors sent me 4's at first and guess what. THEY DID NOT WORK on my 1500. I had to go back and take them out to replace them with the number 3's. Thankfully my buddy that works at acura helped me squeeze them out of there for cheap if I helped him do it on the install machine. Basically any sensors for a non HD 1500 truck will transfer over to a non HD 1500 truck and any HD truck will do the same. All you need is the reset tool.
Edited by jaxcam02
  • 4 months later...
  • 2 years later...
1 hour ago, Paul Pierce said:
On your 20" alloys, did you install the factory Delco sensors or a different make?
If you did change the sensor, what part # did you use?
Paul
All you need to do is make sure your TPMS sensors are 315 MHz, as are most K2s. Also, you'll need a TPMS tool to activate the sensors as you program them.
I'm not sure about the newer models.
I seen it on Amazon for 12$
  • 11 months later...
    Enduro73
    Enduro73
  • Who's Online   4 Members, 0 Anonymous, 1,116 Guests (See full list)
