WTT Method NVs 17x8 and 285/70/17 ko2
jrob56
Feeler on trading my Method NV 17s with 285/70/17 ko2s. Looking to make a change and maybe closer to stock. Sierra All terrain 20s, gunmetal Tahoe Z71s, some of the OEM 22s would be at top of the list. Id consider some aftermarket. Doubt Ill mess with shipping mess, so semi local preferred. Im located in Indianapolis.
No issues on the wheels, tires less than a year old and what little wear has been even. The original coated bolts around the border didnt even last a year. All 100 have been replaced with stainless youll never have to worry about. Will come with the Centers and Lugs.
Pictures in here\/
if only you were a little closer thats the setup im after but i only have the black stock 20's on my silverado
Gone! Running a set of All Terrains with terra grapplers now!
    • Hi, New here.  2026 Denali HD.  Just purchased 7/2/26. I am having the same issue.  I just traded in my 2024 AT4, and the truck connected to bluetooth and Android Auto Immediately!  Now, with the new HD, it connects when it wants to, which is usually not at all.  I have to use the usb-c cable to get it to connect.  Bluetooth won't even connect without the AA. Now after saying all that, I'll take a 20 min drive with the phone plugged in.  Stop at a store, restaurant, etc....  Get back in my truck and DO NOT plug the phone in.  The truck then decides at this point, lets connect BT & AA and work perfectly, ie how it should.   I have deleted (forget phone) the phone multiple times.  I guess I'll just get used to plugging it in every time. even though I don't think its good for the phone battery to have it on charge after it hits 100%. I have searched all over.  No one else seemed to be having this issue, until I read this thread today.   thanks for reading.
    • I have an issue with my ignition hanging and I have to tilt the steering wheel to get in the off position. I have used a great key lock spray and it doesn't help resolve the issue. Is this an ignition assembly issue or something else. If anyone has a past experience with this please advise.   Thanks  Heath
    • This is a terrible GM warranty experience, two months waiting for a covered engine swap with no loaner or timeline is not allowed under GM’s courtesy transport policy.Escalate straight past regular support to a GM executive case manager, document every closed service ticket and dealer repair paperwork. File a complaint with NHTSA to force faster action, and ask for daily rental reimbursement while your truck is down. If it’s been out of service over 30 days, your state lemon law may let you pursue a full vehicle buyback.
    • 198°F isn't unusually hot for an 8L90, so I don't think temperature alone caused the issue. Since everything returned to normal after the truck sat for several days, I'd be looking at an intermittent electronic or hydraulic control problem before assuming the transmission itself has failed. The first thing I'd do is scan the Transmission Control Module (TCM), not just the ECM. GM transmissions can store manufacturer-specific or history codes that won't trigger a check engine light. I'd check: TCM history and pending DTCs Commanded vs. actual gear Line pressure Shift solenoid status Torque converter clutch (TCC) slip Transmission fluid temperature If it happens again, try to capture the data before cycling the ignition, since some intermittent faults disappear after a restart. A professional scan tool that supports full GM transmission diagnostics makes this much easier. For example, the Foxwell NT809BT can access the TCM, read manufacturer-specific transmission codes, and display live transmission data that's not available on a basic OBD-II reader: https://www.foxwelldiag.com/products/foxwell-nt809bt Hopefully it's just an intermittent control issue, but I'd definitely pull the TCM data before replacing any parts.
    • Sorry, I accidentally posted in the wrong language. I'll repost it in English.
